Bill.Satellite wrote:
1Longbow wrote:
We have a stationary antenna on top of our TT. It sits about 8 inches off the roof. What would you all suggest for a better antenna replacement,that does not require a lot of work,but would improve reception. Thank you
If it looks like a flying saucer then most anything is an improvement. The best is the Winegard Batwing antenna but this requires drilling a hole in the roof. It's not hard but you have to have a bit of knowledge about what you are doing.
Winegard makes a dome style antenna called the Rayzar Automatic which has a directional antenna inside and could likely be installed without running any new wiring.
We had a flying saucer antenna on our 5er. Really wasn't much of antenna. Would have installed a conventional batwing version, but with the high ceiling in the 5er we wouldn't have been able to adjust it.
We replaced the flying saucer with the Rayzar Automatic. Works much better that the old one, but probably not as good as a batwing. The install was pretty easy. Cost more than we wanted to pay, but it is an improvement from what we had.
