KD4UPL
Feb 11, 2014Explorer II
There's really no meter to test the jacks. A TV monitor is what's needed and you have that. I would make sure you TV is set for the correct input your hooked too. It may have 2 or 3 such inputs.
I would also make sure your head unit doesn't have a setting where you can turn on or off the second output.
Are you sure your cables are good. It would be very unusual for all 3 to be bad at the same time but you never know.
Are you sure the jacks by the TV are outputs? They may be inputs where you could connect a game system or something and play it thru the head unit.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
