jeffo wrote:
I am thinking about buying a Tailgater and a 211 receiver. The latest version of the 211 is the "Z". I will be going from the 211 to a Quest Video Control Center that only has coax for the sat. in connection. The Z uses HDMI or RCA , can I convert one of these to coax without losing to much pic quality? Or should I get the older 211k which also has the coax out?
Jeff
Yes, you can convert the RCA connections to coax output using a RF Modulator. You don't lose anything other than no HD. Now watching SD instead of HD is a dramatic loss but if you are comparing using the SD RCA output compared to the RCA/RF Modulator output, they will be the same.
The only way to get HD to a TV would be via HDMI.
