MrWizard
Aug 23, 2023Moderator
What is the display resolution of your TV ?
720p 1080p 4k ?
Best guess is you are trying to send a 4k phone display to a 1080 TV
You need to change the app settings on the phone, to display at 1080 resolution so the signal on the cable is compatible with your tv
The apps in question, should have an option for displaying a lower resolution video choice,
That is where i would start,
the phone and apps can decode video using newer compression that the TV can not process this goes hand in hand with 4k video signals, you need to use app video settings that are compatible with your tv
720p 1080p 4k ?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
