wa8yxm
Sep 28, 2016Explorer III
Ok, how to do this may take a bit of reading but first access the Antenna pointing page. On VIP receivers you wait for it to fail, then press the * Key on the remote if I recall correctly..
Now, on the antenna page enter the ZIP CODE that applies to your parking spot and then select sat 110 or 119 (i'd go for 119)_ and the type of antenna you have (500 or 1000) You will get 3 numbers
Azimuth, Elevation, Skew
On the tripod, Make sure the mast the dish is mounted on is plumb (Straight up and down, not tilted (Shim and adjust as needed to get there.. Then tie the tripod down DO NOT SWING WEIGHTS, make sure the weight (if you use that method) sits upon the ground, or stake it down (The CLAW from Harbor Freight)
Now preset the Elevation and tighten just enough to be snug, Likewise the skew (Tilt)
Now while watching a portable color TV attached to the Receiver SLOWLY swing the dish through the azimuth (use a compass) I like to start on the east side and work west.. When it peaks, Snug that down a bit, Now push/pull gently on the top to mess with the elevation and see if the signal improves/gets worse. If it improves peak it and re-adjust azimuth. You should not need more than 3 itterations (2 repeats) to finish the job. now tighten well, Job done.
Two notes
1: The hardest part of this is waiting for a VIP to error out so you can press the * key.
2: By the time yove done it a few times you will finish faster than I typed this and I type fast.
Two notes
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
