rhingst's avatar
rhingst
How to connect to wireless printer
We have an AT&T mifi and a Verizon mifi. I have the AT&T mifi working with our HP wireless printer but am not able to get the Verizon to connect. I put the Verizon mifi password in the 'modify credentials' when it asks but it still doesn't work. What am I doing wrong?
  • I have and HP Laser jet P1102W connected wireless through my Jet Pack
    I will tell you that it took several tried to get it working correctly.
    First make sure you don't have anything else connected to your MIFI such as another router I did and I think the printer could not decide which on to connect to . After turning off the router and removing the printer from the computer I tried reinstalling and it worked.
    Make sure you go into printers setting and remove the printer before tring to reinstall it.
  • It's possible they may be using different security protocols. For example, the printer may support WPA while the MiFi is using WPA2.
  • I was told your better off to connect the printer to your computer when using Verizon mifi. I tried it too and it just didn't work.
