- Surviver76ExplorerThanks to all for the great responses...
- TechWriterExplorerI'm using WiFiRanger Core and SkyPro.
- wa8yxmExplorer IIIOk, how about a multi-function box....
I will tell you how I've done Internet in this RV over the last dozen years.
I started with a LINKSYS Wireless game adapter (no longer made) which is kind of like a Wi-Fi "Modem" That is it connects to the HOST Wi-Fi but looks to stuff in my RV like a Cable Modem.. It fed a Common home router.. I've had 3 different makes.. I do not recommend Belkin (Which I'm using now) but frankly there is nothing wrong with 'em.
Recently,, I ordered an Umibuqitty Nano Station Loco M-2 (Just google Nanostation M2) I got the cheap one.. I suggest a better one, IT replaces the Linksys with only a couple of changes (Power is way easier to feed it,, that's the biggest change,, Plus a bit of "learning")
Setting it up takes a bit, since the docs suck, but I got it done.. Now where I am now I'm a bit far from the park router for the M-2 "The M might make it)
They have devices that can see for several miles provided a like device is at the other end of the link.. Less with common house routers
The path
Host ))))) Nano-station ====(Cat-5 I have 100')===Belkin router )))) Stuff in RV (Also cat-5 to some stuff)
Setting up
Access your router's config page, Set to static IP 192.168.1.anything between 1 and 255 EXCEPT 20.. (NOTE this i9s the WAN IP, not the LAN IP)
Go to 192.168.1.20 (The Nano-station) Override the security warning and log in (Ubnt is both user name and password) Go to WIRELESS
Click on SELECT next to the access point.. choose the one you want.
Click on LOCK TO AP
If a pre-shared key is needed enter it in the box near the bottom of the page under Security Type.
Click on CHANGE (Very bottom)
Click on APPLY (very top)
Click on MAIN.. You may need to re-laod a couple times for it to re-load.
You shoudl see a signal bar, If needed you can adjust the antenna direction a bit to make the bar stronger.
Now go back to your router config and select DYNAMIC IP
And that.. Should be.. That. - pianotunaNomad IIIBoosters are more about keeping a connection active than about increasing speed. If there is an adequate signal without the booster--it may be faster than with the booster on.
- The best you will be able to do is 'boost' your WiFi signal to the main source and your internet speed is then dependent on the source internet speed.
For example, I have Xfinity cable internet in my house. It's the 100 mbps package.. I get pretty much that speed on my desktop that's connected with a cat 5e cable to my WiFi firewall that's connected directly to the cable modem.
On my laptop, and the desktop computer I have setup for Amazon Prime in my TV room, that's connected via WiFi, it only gets a fraction of that speed...
It's about 50' away with a couple of walls inbetween .. My computers say I'm connected to WiFi at 130mbps, but when I do speed tests on the WiFi computers, I'm lucky to get around 20 mbps speed rate. On the desktop that's connected directly to the firewall, it's over 95 mbps.
Anyway, I'm working on hard wiring my Amazon Prime computer in the TV room, but to be honest, I can still stream full HD video on the WiFi setup... So, it's not been on the top of my project list... :)
But, if you have a lousy WiFi connection, your speed will reduce accordingly..
Good luck!
Mitch
On Edit, I know that if I'm streaming on the Amazon Prime computer, using WiFi, and I'm on the laptop, say on a remote desktop connection to work, my laptop connection is a lot slower than normal..
I've even noticed if the microware oven is running, my WiFi connection goes down...
Just saying that WiFi is not the same as being hard wired to your modem..
Mitch - pianotunaNomad IIIHi,
I'm currently using this device: https://www.amazon.com/TP-Link-Extender-Extends-Devices-RE200/dp/B00NR2VMNC/ref=sr_1_9?s=pc&ie=UTF8&qid=1497812585&sr=1-9&keywords=netgear
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
