Gdetrailer
Jun 01, 2022Explorer III
If your rig has fiberglass siding, the outside braid of the coax is most likely acting as a "counter poise" or "groundplane".
By unwinding and unbunching the coax you increased the counter poise or groundplane improving reception.
Basically as is it is the same as this..
A wire "dipole"..
I have had zero luck where I live using wired dipoles and even folded wire dipoles like this..
Since most of the radio stations I have are 40-50 miles from me..
You might need a new plan of attack, longer whip plus some metal near the antenna to act as a ground plane or counter poise..
If you can remove the ducky mast leaving the mount in place, perhaps try adding a metal rod twice the length to where the ducky was connected to see if that improves things..
A wire "dipole"..
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 28, 2026
