d3500ram's avatar
d3500ram
Explorer III
Aug 04, 2018
How to transfer data from one laptop to another...?
I have a 10+ year old computer that has served me quite well and is still working.
I bought a new one recently and am getting used to it (Windows 10, other program UI's, etc)
What is he best way to transfer data from the old one to the new? I know I could drop stuff to a thumb drive and physically move it over. I do not use any cloud based services so that is out.
I do not believe that I can connect the USB from one computer to a USB of the other (can I?) ...but this is essentially what I want to do, but not sure how each others' "C" drive would be recognized. I guess I would like to have some sort of direct wired connection between the two in order to transfer.
I do have a 4T external hard drive, but that is, for all intents and purposes, is just a larger thumb drive in terms of transfer method. I am not some IT wizard in terms of technology and if it going to be big production or if there is a chance of screwing up the new one I will eventually take the time to archive to the external drive and then piece-meal the restoration to the new one as needed.
The new one is quite a performance improvement over the old! I especially like the solid state hard drive, Xenon and 64GHz ram along with all the other goodies. Only regret is not dropping a little more jack to step up the video card again. I intend to use it fro AutoCAD, REVIT, Sketch-up and Lumion.
  • Big Katuna wrote:
    Buy a data transfer cable, $20 delivered.
    It’s a special USB cable. Amazon, Walmart or Best Buy.
    Yes, but a 32GB thumb drive on Amazon is $6.99 (if you don't already have one) and requires no software installation like above. Simplest and easiest, even easier than if you have a router due to need to create shares between the two computers on your network. And it is much easier then pulling the old computer hard drive and putting it in a case for attachment to the new computer.
    OK... am researching this option. How hassle-free is it?
    Will I see on one computer monitor of the opposite's hard drive in order to visualize the drag from the old in order to drop to the new?
    Old computer= Vists OS
    New computer= Windows 10
    Unless you have more data than the external drive will hold, I think this is the best idea. When complete, the external drive will be a backup.
  • Buy a data transfer cable, $20 delivered.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Well first there is a USB/USB cable
    And if you can connect them both to a common router you may be able to do a lan transfer.
    On older laptops the Hard Drive is generally a real hard drive. remove it and plug it into a Shell (any computer store) and plug it into the new drive (done this)
    Finally I would indeed use a thumb drive.. and have a few times.
  • Network them together and simply Drag-and-Drop. On older vintages of Windows you could use a twisted pair network cable and transfer that way, but I doubt that Windows 10 would allow that.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 31, 2025
