lakeman48's avatar
lakeman48
Improve campground WiFi signal
Would like to use my Roku streaming device on campground WiFi signal. What do I need for hardware? Is it practical? or do I need my own Hot Spot? If so what would I need for that? Would like to stream movies and tv.
  • Thanks for the info. Will forget about using campground WiFi and look more into Hot Spots.
  • Streaming is not a feasible option on campground WiFi. Bandwidth is limited and streaming will hog what's available. Many campgrounds will shut you down if they discover you are streaming with any device.
    Streaming will consume your cellular data plan like crazy. Unless you have a HUGE data plan, this will cost you big $$$.
    We have two Rokus, but only use them when we are stationery for a few months and are connected to local DSL or cable.
  • If you want more reliable signal, I'd invest in your own hotspot. CGs are getting better with their WiFi, but they are still iffy, and you may have one with a very weak signal, and the Roku would probably not work well there.
    Personally, I'd get the Hotspot (which usually has a trial period for a week or so), and take it out for a trip...try it, and then decide if you'd do better with DVDs, or downloading movies to your computer, if the signal isn't enough for the Roku. At least that way, unless you have other uses for the hotspot (I take mine to work on the tugboat), you won't get stuck with a monthly fee and contract.
    Good luck:)
