mdgibbs88
Mar 21, 2023Explorer
I had the same problem on my Cougar 316RLS. Talked to the folks at InCommand and they were very helpful. Turn power off at the screen by holding the power button until the power off message comes up. Hold the power button down until you see a white flash and let go of the button. You should bypass the Travel Lockout message and go right to the login screen. You should be good to go at this point, but I found out that I needed to do a software update and that fixed the issue.
Good luck!
Good luck!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
