tjatkinson's avatar
tjatkinson
In Command Travel Lockout HELP!!!!
We just bought a new RV with the In Command unit. We have unhooked the RV and leveled it, but our slide and our awning will not work, because our Iphones say we are on a travel lockout and each system says disabled without the option to enable it.
Can anyone help us?
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to posting issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM POSTING HELP AND SUPPORT
  • We did that. The wall mount does not read Travel Lock but our phones do, which is not allowing the change.
  • Here is a link to a manual for the In-Command System. Page 9 has information about the Safety Lockout feature.
    Here’s a paragraph from the manual that might help:
    SAFETY LOCKOUT
    IN-Command is equipped with a Safety Lockout feature to ensure certain system functions are unavailable during transit.
    When the Brake or Right Turn Signal on the tow vehicle is activated, IN-Command will lock down all motorized functions. A red button, with Travel Lock in white text, will appear on the DC and mobile devices will display “Travel Lock On” in red letters. All motor functions will cease to actuate and Disable will be written on their buttons.
    The lights, water pump, water heater, and sensors will continue to function.
    To turn the Travel Lock off, ensure 12VDC is not going to the Travel Lock system by removing the 7-way connector from the tow vehicle and press the “Unlock” button on the Display Commander inside the RV.
  • Sorry, no experience with that system. There’s no inside override?
