PandS's avatar
PandS
Do Command Strips work in RVs?
I would like to mount a clock in our Ventana. The clock weighs 3.5 pounds, and is mounted in a 11.5 x 15 inch wooden wall plaque. I’ll need to take it off the wall to change the time, change battery, etc. I don’t want to put holes in the wall, plus our studs are metal, not wood. I am thinking of using a LOT of Command Strip picture hangers. These use the same Command Strip adhesive that can be removed by pulling on the strip that that sticks out, put are plastic Velcro where the two sides meet. The ones I have say they’re good for 16 pounds. Has anyone used these in an RV? Will they holdup to the bouncing while traveling on rough roads, and the heat of storage?
