96Bounder30E's avatar
96Bounder30E
Explorer II
Apr 01, 2015
Inexpensive wifi wireless security camera
I know the subject of home security cameras comes up from time to time on the forum...
I was looking for a IP camera that is easy enough for my mom and dad to operate with my initial set up...
I was looking at the Dropcam by Nest....but the $200 price tag was a little steep....while cruising ebay I came across the one linked to at the bottom....I did a best offer of $33 and they took it.....
Unless you are familiar with Port Forwarding through your router, set up can be a real pain.....this camera required no port forwarding.....I had it up and running in less than 5 minutes
While it doesn't have PTZ (Pan, Tilt, Zoom) it's screen quality and features are excellent......it has a motion alarm with email and text style notifications......
Wireless IP Camera HD Add-Drop Security IR WiFi 720p P2P Night Vision Baby Home
Although I have not tried it......with a smart phone and a hot spot I believe this could be set up to be used in an RV.....
  • 96Bounder30E wrote:
    I used to have problems with them switching IP addresses after a black out....until I learned how to turn of the DHCP......
    learn how to do "DHCP reservations" in your router, although what you did works just as well
  • Jeff,
    I have 3 foscams and 8 wired Lorex cams......The Foscams are rocksolid once you get over the learning curve.....I use a No-Ip address for my DNS......I used to have problems with them switching IP addresses after a black out....until I learned how to turn of the DHCP......
    For the money, A PTZ Foscam is a great camera......
    The Dropcam clone I referred to above is nice in that there is not the set up learning curve......
  • Foscams....Real easy to use once set up. I have three of them around my house as my wife and I travel a lot. I can quickly look at my phone and see if the fort is secure. And it is set up with an APP my son installed that it records video if someone moves in front of the camera. You can yell at them and hear what they are saying. I belive I paid $60 each at Amazon.com
  • I'm using the Foscams and they have been rock solid for several years. While they do require Port Forwarding setup, once it's done, it's done. I do believe that anything that doesn't require that setup needs a DNS account (?).
    What's nice with the Foscam is that if power is interrupted, like a blackout, when the camera reboots, it emails me the ISP IP just incase it changed with the outage. Does that one?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
