LarryDel's avatar
LarryDel
Explorer II
Jul 17, 2018
Installing Portable Satellite in our new motorhome
We just purchased a 2019 Forest River Forester Class C and we've also purchased a portable satellite dish. The instructions that came with the satellite dish say that you need a direct connection from the satellite to the TV which means we can't use the cable hookup on the outside of the motorhome, but we don't want to drill a hole in our new RV. Is there a way to use some sort of splitter system between the cable and the satellite. Thanks for your comments.....
  • Some new MHs come with a satellite connector installed on the exterior of the rig. You need to check to see if Forest River did or did not do this.
    If it is not you can get a through the window cable device. It fits through sliding windows.
  • I've always installed a direct to the receiver coax and bulkhead fitting inside a bin with pass-thru to the outside for my satellite dish hookups. I usually replace the cable fitting cover plate with a dual fitting plate and label them accordingly.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
