mr__ed's avatar
mr__ed
Interpretting System File Checker Results
My PC (W10 Pro) is running very well, but I decided to do a check with SFC /scannow. It came up with the following results:
Windows Resource Protection found corrupt files but was unable to fix some of them. For online repairs, details are included in the CBS log file located at windir\logs\CBS\CBS.log. For example C:\Windows\\Logs\CBS\CBS.log. For offline repairs, details are included in the log file provided by the /OFFLOGFILE flag. PS C:\WINDOWS\system32
i don't understand if this is important and what must be done. Thanks for your input.
  • CA Traveler wrote:
    Is W10 Pro at the current level?
    Yes, I believe it is. Version 1803. Right now computer is running quite well. If I have any issues I'll just reset it (reinstall W10). Since a working computer is very important for me, I recently purchased an RCA Viking tablet, running Android.
  • This article has some info (probably just as confusing) that might help.
    It also suggests the DISM command might be able to fix some of it.
    https://support.microsoft.com/en-ca/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness
    I had this problem a while back, but subsequent major Windows 10 OS updates seemed to correct the problems. I now usually get a clean report from the SFC /SCANNOW command.
    As to how important is it? Probably not, if the machine/Windows seems to be working normally. If you start getting other odd errors or system crashes (aka, inexplicable BSOD) it might be worth pursuing.
    I'll run a scan and see what happens and update this thread later.
    SCAN RESULTS: No problems found.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
