Roy_Lynne's avatar
Roy_Lynne
Explorer II
Nov 17, 2016
Is there such thing as a satellite radio antenna boaster?
I swear if there is a tree within a 100 yards of my van, I lose the signal and I don't have the same issue with my car. Can you get stronger antennas or boasters?
  • and, if your antenna is more than 3 years old, you might just replace it. I was having receiving issues with my old Starmate III that has a lifetime subscription on it, and Sirius told me to just replace the antenna. I use those little magnetic dot antennas and a new one made all the difference
  • How old is the radio? Some of the older receivers are real dogs. Sirius tends to work a little better in the northern area foliage too do to the orbital path of those satellites
    A new antenna should be fairly inexpensive.
    What kind of antenna do you have now ?
    Have you tested the connections ??
  • I have the standard magnetic antenna that I use on the roof of my truck or dashboard of my SUV and there are a few areas with tall trees on the right side where mine blacks out momentarily. don't think a booster will change that.
    bumpy
  • If its a factory antenna get an aftermarket magnetic mount antenna off ebau and try it.
  • Booster? Probably, but I doubt it's practical.
    An external antenna would serve you better. is your radio after-market or OEM?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
