ScottG's avatar
ScottG
Nomad
May 04, 2015
Jack ant. stop
My Jack antenna's stop is broken - this is not the one that you put on top of the old bat wing mounts, it's the freestanding unit.
It will spin more than 360 degrees now and I can turn it around several times. Not sure how it got busted, may have been when we removed the cover.
At any rate, I don't remember how the head was built from when I installed it. It doesn't look like the stop is inside the trailer so I suspect it is outside in the housing under the wing.
Can anyone confirm this? Did I just miss it when I checked the inside components?
Scott
  • Without the stop working you have to be careful not to loosen the coaxial cable attached to it. The stop is likely inside the unit. Do you have the installation manual thatcame with it?
    If not then download one from their site.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
