bkenobi's avatar
bkenobi
Happijac TC jacks stop, no light
2007 NL 10'2QRR. tag says 2425# dry, but I beleive wet and equipment is closer to 3500# (haven't checked). HJ system with wired remote and 4500/4150 jacks.
When loading the camper from the ground (was dropped way down so a long lift), the HJ system stopped many times after around 10-15 seconds. The light on the remote would turn off and no response to button presses. After waiting a few seconds things came back to life. I did joggle the plug, but I beleive that didn't affect anything.
The dealer thinks it's the circuit breaker in the battery compartment. That's an easy change, but is that a reasonable culprit? I measured load on each jack when lifting and it was 4-5A. Total load on controller was over 20A. the breaker is rated at 40A, but the terminals have a fair amount of corrosion. Is this a good first thing to replace? If so, I'd just replace all 5 at the same time.
