Tom_M1
Jul 16, 2014Explorer
The Jack is a direct replacement for the batwing head. You do not need the "Jack booster". It is not a "booster" but a power injector. Put all the wiring back the same as it was for the batwing. Remove the SureLock. Make sure the LED is lit on the Winegard wall plate. The Jack has an LED on the bottom side that indicates that it is getting power but is difficult to see in daylight. Now point the Jack toward the TV transmitter sites. The flat part of the Jack is the front of the antenna not the pointed end. Do a scan on your TV. If all is good, you can now reinstall the SureLock.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
