Mover480's avatar
Mover480
LTE Filter with RV TV
Anyone use an LTE filter in their RV with the TV? If so, where did you install it? At the TV or on the coax at the amplifier? Does it need to be removed if you are connected to cable or can you leave it in place?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    MY TV's.. even 100 mW on 433 MHz is enough to bother 'em So if there was LTE interference I think I'd know it.
    This message brought to you via LTE and TV is working perfectly
    I agree with GDE. if you do not need it do not waste your money on it for it will likely do more harm than good.
  • Unless you are parked directly UNDER or beside a Cell tower, should not need a LTE filter.
    Putting any uneeded device like a filter or even a splitter can also reduce the valuable little bit of signal a RV antenna gets. So, unless you are having issues with specific TV channels which are on the top edge of the UHF broadcast frequencies there is no need for a LTE filter..
    Just another gotta have gadget that makes someone else money and does nothing for 99% of the time of the person buying it.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
