berreez's avatar
berreez
Lube Pump Front Wheel Drive
I noticed on the Camping World website that I can get a lube pump for a front wheel drive vehicle for flat towing.
Since I found out my 2008 Ford Escape, XLT, f/wheel drive automatic isn't flat towable this seems like it will prevent me from getting another car just to tow.
Has anyone tried / used this product? Does it work and hold up?
Any thoughts?
  • Bumpyroad wrote:
    wbwood wrote:
    I think he was just saying that if it stops working, then you will have serious problems.
    do a search. there have been issues with them. don't know the % of failure rate but if it is yours that stops working it is 100%
    bumpy
    Thank you. I did a search and found the post about the the guy whom had a leak defect in his pump thru the wire outlets.
    bumpy
  • I think he was just saying that if it stops working, then you will have serious problems.
  • Bumpyroad wrote:
    those lube pumps work fine until they stop working.
    bumpy
    Bumpyroad, do these pumps have a problem like not working very often or were you making a joke? What do you know about them? Been considering buying one, but not if they have a high failure rate.
  • You can also look for lube pump for a front wheel drive vehicle on the Carpartkings, there a lot of necessary things i found, which can be useful
  • These lube pumps come from Remco Towing. There is not an application for the 2008 Ford Escape. Per the manufacturer of the lube pump this vehicle must be towed on a tow dolly or trailer.
  • I had a Remco transmission lube pump on my '99 Regal toad for 3-4 years with no problems. You should make sure that the transmission getting lubed is the only reason not to flat tow the Escape.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
