- LynnmorExplorer
SidecarFlip wrote:
I used CCleaner and have for years. Nice program, Have it on my Android phone too...and it's freeware.
Be sure that you are aware of this Security Notification - AllegroDNomad
sherlock62 wrote:
All this is not necessary! All you have to do is right mouse click on the Malwarebyte's icon in the task bar and then remove the check mark where it says Open when Windows starts.
This is the answer. I would not uninstall as MB is very good. - downtheroadExplorercCleaner is excellent but has a completely different function than Malwarebytes.
- SidecarFlipExplorer IIII used CCleaner and have for years. Nice program, Have it on my Android phone too...and it's freeware.
- braindead0Explorer
sherlock62 wrote:
Or simply uninstall the free program if you don't like the conditions.. that's pretty easy.braindead0 wrote:
az99 wrote:
You most certainly can prevent it from starting up, it's either in one of the startup folders, a windows registry Run key or (less likely) being launched as logged in user by a service.
It would be real nice if they informed you what you are going to get when all you clicked on to do was an update. Be honest and tell the customer they are being forced to use the premium version for a trial period.
The program also auto starts at boot and you can't disable it in startup of Task Manager.
Try running msconfig, that should give you a handy user interface to disable startup of anything. Be warned you can disable startup of necessary items using this. Start with the 'Startup' tab, sort by Manufacturer and you should find it easy enough. Uncheck, follow instructions..don.
All this is not necessary! All you have to do is right mouse click on the Malwarebyte's icon in the task bar and then remove the check mark where it says Open when Windows starts. - sherlock62Explorer II
All this is not necessary! All you have to do is right mouse click on the Malwarebyte's icon in the task bar and then remove the check mark where it says Open when Windows starts. - wildtoadExplorer IIJust keep in mind, some folk are less technical than others.
Try running msconfig, that should give you a handy user interface to disable startup of anything. Be warned you can disable startup of necessary items using this. Start with the 'Startup' tab, sort by Manufacturer and you should find it easy enough. Uncheck, follow instructions..don. - sherlock62Explorer II
More misinformation from az99.. Someone needs to double check stuff before posting crapola here.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 31, 2025
