Monty-Rob's avatar
Monty-Rob
Mifi same as phone hotspot?
Does a. Mifi card pull in the same signal as using your phone as a hotspot?
We have Verizon...
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    We have Verizon...
    Short answer YES.
    Long answer: Though the MiFI and the cell phone both use the same towers and signals, In theory both should work equal to each other provided they are the same "level" (G3-G4-G4 LTE) and generally this is the case..
    it is far easier to set your Mi-Fi in a sealed box on the roof or up a flagpole if you need to than it is your cell phone (Height is Might in the signal game).
    Plus an incoming voice call, Depending on your phone, may shut down internet till the call is completed (or not) and with a Mi-Fi the call comes in on a different device.
  • cyntdon2010 wrote:
    I also have Verizon, I use a AB called pdanet+ for a one time fee. I have wifi for free for laptop.
    What is that?....is it throgh Verizon?
  • I also have Verizon, I use a AB called pdanet+ for a one time fee. I have wifi for free for laptop.
  • Yes its the same they are using the same communication chipsets, some units may offer an external antenna but they are rare and expensive.
  • Technically, it's the same. There may be some variation in signal strength, etc. Also, when your phone is busy doing other tasks (such as an incoming call or text message) you may see a slow down in your internet speed.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
