SCVJeff
Dec 18, 2016Explorer
1- In DirecTv world, 75 is a mediocre signal at best and it won't take much to lose lock from there. JUST FOR YUKS: tape a penny at the dish feed hinge, using it as a spacer lifting it ever so slightly, then stow and repoint the antenna. I had a similiar problem and fixed it with a small piece of aluminum angle to refocus the feed back to the parabola, rather that paying Winegard for an entire new assembly. On Direct it brought my sat feeds up between 3 to 8 points depending on the satellite.
2- You say you haven't moved? It could easily be local interfearence, including LED RFI generated by you or your neighbors.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
