pconroy328
Apr 24, 2017Explorer
full_mosey wrote:
I am working my way through the MS MODBUS Specification specs to capture data onto the RPi3.
The plan is to avoid fixed control panels, and instead, run a web server on the RPi3 and then view info via smartphone, tablet, laptop, etc clients. A mifi will provide LAN connections.
As of last Friday, I have been capturing the 'RAM' data fields for each minute. The fields are listed on page 4.
I have no plans to use spreadsheets. I store the data in an sqlite3 database.
Here is a sample output from an sql query run from the sqlite3 CLI:
day cs cstate avg_bvolts min_btemp max_btemp minutes
2017-04-23 3 Night 12.93 9 25 620
2017-04-23 5 Bulk 13.35 9 26 178
2017-04-23 6 PWM 14.86 10 22 328
2017-04-23 7 Float 13.36 22 27 314
The query displays a summary of the minutes for each control state for the previous day.
The bank is 270ah AGM which should explain the high Night battery Volts. I do run two 12V compressor fridges 24/7.
Looking for Comments, Suggestions, Questions.
HTH;
John
Comment Number 1: COOL!!!!!!!!!! :)
Number 2: Sounds like you're a RPi expert but just my two cents: invest in a good microSD card if you're hammering the card with IO, like sqlite will do. I have 6 RPis in the house, and when I buy cheap SD cards they last about 8 months. I bought a couple of Samsung SD cards and they've gone three years.
Web Server - Not sure if you have a favorite, but if not I've been running lighttpd on my home Pi and like it. Small. Solid.
I've got an RPi3 with a SensorHat in our coach collecting environment and OBD2 data. I'll follow your lead if/when we add solar!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
