full_mosey
Jun 20, 2017Explorer
Here is a graph showing the progress of charging during one day.
I got a clamp-on DC Amp meter for father's day. The brief drop of battery Volts at around 8:30 is me testing the meter by running a 480W space heater from the inverter. The other dips are due to the cycling of two 12VDC fridges while the charge Amps are lower than the fridges' draw.
The stair stepping of the Target Volts is the temp-comp function of the controller reacting to increases in battery temperature.
HTH;
John
HTH;
John
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
