mike-s
Jun 27, 2017Explorer II
full_mosey wrote:What makes you say that? As I pointed out, the accuracy of current measurement based on the Morningstar manual seems to be 0.3+ A. It may even be around 0.6 A, which is 2% of the -15 to +15 A range. And, do you know and trust the accuracy of the meter you're comparing against?
The known RPi Amp draw of 0.33A per the DROK is nowhere to be seen.
You might want to review the difference between accuracy, precision, and resolution. You seem to be assuming that because your data seems precise with high resolution, that it's also accurate.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
