Mikesr's avatar
Mikesr
MPEG 4 Chipset TV Questions
I don’t know much about this subject and thought I would ask some questions here.
We have a travel trailer setup for the remainder of the football season near Sate College PA and the campground owner tells us his cable tv provider switched to an MPEG 4 technology and that is why our TV’s are only getting some of the channels we previously received at this same campground on the same 3 TV’s we had last year that are not that old, We have scanned and rescanned each TV several times with different results of found channels on each one and some channels saying audio only. The campground owner suggested replacing the TV’s. We do not have a problem with this but finding one that is MPEG 4 chipset seems confusing. Looking at specs of various 32 to 49 inch TV’s and do not see it specifically saying MPEG 4 chipset.
Anyone have suggestions, input or recommendations on a TV or different solution that would work ?
Thanks in advance
  • Cable Cos in State College PA per HERE..
    Comcast Xfinity..
    From what I can tell, unless you have one or two specific brands of TV you WILL need a set top box (AKA Cable Converter)..
    From HERE it is claimed that only Samsung (the first set) and later 2018 LG sets will be compatible with Comcast cable directly without a set top box.
    Cable Cos have pretty much pulled the plug on analog channels and even have set the QAM data bit to "private", they are no longer compelled to provide open in the clear cable signals PROVIDED they offer FREE basic set top boxes..
    OP should be able to contact the local cable Co office to get full details on a free set top box to use..
    I suspect the campground may even have those boxes..
  • Think the best solution is a cable set top box that receives mpeg4. Don't know about splitting it up or if you will have to get three.
    The above STB is for antenna reception I think, you need one for cable.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok, Most modern flat screen TV's do MPEG4 just fine. It's the "Standard" video format for Windows computers after all.
    What has happened is SOME cable companies are now Encrypting and you need a set top decoder.. This may have happned along with a switch from "Mostly analog" to Digital.
    ORiginally cable systems were analog
    Then they went to a digital format called QAM (Quaduature Amplitude Modulation)
    Then the world went digital for broadcast
    Some Cable companies pass on ATSC Some QAM and Some digital and most mixed.
    QAM allows for encryption Most modern TVs (one brand is notabally and exception) DO NTSC (The old analog National Televiosion Standards Comittee or Never Twice Same Color take your pick)
    ATSC (American Television Standards Comittee) Digital OTA broadcast
    QAM But NOT QAM encrypted
    ANd MPEG (via the USB port)
    ELEMENT TV... the only one made in the USA and I'm not sure if they still are as some plants have been closed.. IS also the only one I know of that does not do QAM.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
