Acampingwewillg
Jan 11, 2023Explorer II
Multiple access points?
Don't be to hard on me with this question!
So for Wi-Fi while RV'ing I use one of three separate Cell phones as hot Spots( that would be two T Mobile network phones and one Verizon network phone), I do have a Wilson directional Cell booster and finally I have one of those AT&T network Dome antenna's on the roof that also acts as a Wi-Fi booster.
If I recall correctly( haven't been on a RV adventure in a couple years) my Dome can act as an access point? Or is that what it is called where you can input all the passwords thus allowing the access point to choose the strongest signal between those that are entered?
In the past, I did everything manually, switching from one hot spot to another....I guess the reason I'm asking is if you have devices set to one password and that signal becomes unusable while another becomes available, can a separate device chose the from multiple access points with different passwords and spit out a universal Password allowing the devices to continue uninterrupted?
Hope I'm asking this correctly enough to understand.....
