marpel's avatar
marpel
Navigation options
As per another post, I am beginning to look for a new truck. Have been to a couple dealerships and have done some preliminary net Price and Build queries.
I have been surprised that not all/most new vehicles have in-vehicle GPS nav, outside of premium packages, and a salesman told me many get one of the packages with a monitor and no nav, but with the ability to sync with a cell phone, from which they use Waize (sp?) or other, in fact he said that's what he uses.
So, my question, which I did not think to ask at the time, how does this set-up work in areas with no cell service?
Marv
  • Thanks everyone for the replies and all the info.
    So, just so I am clear. If I use a cell phone and e.g. Waze, does downloading "the map" before I leave, mean a map of the whole U.S. or a map of the planned route (we routinely travel to/from Denver, Co and BC, Canada with unplanned deviations in routes/way-stops where no cell service is common)?
    If an entire country/continent can be initially downloaded, then I don't likely need a traditional navigation system.
    Marv
  • https://copilotgps.com/en-us/CoPilot GPS is an app that works offline AND is RV aware. You enter your height, propane etc. and it will route you accordingly. It's not free like Google or Waze. The RV version is $30/year.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    you need cell service for phone/messages etc. For NAV all that is needed is GPS coverage as long as the map is already loaded into the device, and the cell phone will get that as will the NAV system even with no cell service. Now traffic info etc. needs cell service as well.
  • OK, someone tell me which Internet Map base you use that can let you input your RV's height into so it won't route under a low overpass???
    My Garmin allows me to input height, weight, and length to keep me off of roads I shouldn't be on.
    After all this is an RV Forum.
  • LouLawrence wrote:
    The post above is wrong. You don't need cellular for the entire trip. If you know you are headed to a no cell zone you can download the map before you leave. Otherwise, Google Maps and WAZE will keep the route ahead downloaded to your phone and you will have no idea when you run in or out of cell service.
    You don't need a stand alone GPS (especially a built-in which is a pain to keep up to date). Plug in your phone and you will have the most up-to-date information for routing plug minute by minute traffic updates and POI information the GPS units can't touch. Google and WAZE will even keep up with temp road closures due to construction which would take a year to get updated in a GPS system.
    1) Can Waze be configured to route big rigs around low clearance overpasses, weight-limited bridges, restricted roads, etc?; and 2) how much data on the cell phone plan does Waze typically use?
    Rob
  • Find a friend with a truck that accepts and displays your cell phone’s maps. My iPhone and 2020 Silverado work great together.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    My Cell loaded the map at startup (With internet) then so long as you did not CLOSE the map app you were golden... I also have a darn hood geo-memory so even if I lost the phone map I was USUALLY at least silver if not Gold.
    Now it's kind of hard for me to find "NO COVERAGE" spots.
  • The post above is wrong. You don't need cellular for the entire trip. If you know you are headed to a no cell zone you can download the map before you leave. Otherwise, Google Maps and WAZE will keep the route ahead downloaded to your phone and you will have no idea when you run in or out of cell service.
  • It won't. The cell phone needs the internet to load the map tiles. For navigating with no cell service you need a GPS device with the maps built into it's memory.
    I spend probably 2 days a week in the mountains of VA and WV with no cell service. I have a Garmin GPS that mounts to the windshield with a suction cup. I think it cost about $300. I move it between our 3 vehicles depending on what I'm driving. I've even taken it on my boat to find an address by water. I just can't justify the huge cost of a built in navigation system, particularly when it only works for one vehicle.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
