theoldwizard1
Jan 12, 2020Explorer II
Sadly, most of the RV specific components are junk. Lots of car audio stuff, but the pricing is not that great and probably over powered for what you want. This of course leads to the large selection of residential, 120VAC equipment. If it has a "wall wart" power supply, you can buy moderately price DC-DC converters and then run everything off of 12V.
If this is a "build from scratch" or major (new walls) remodel it is time to run more 12VDC power lines through all of the walls. Use 18AWG Marine Grade tinned copper, duplex cable and 2 port USB outlet charger
USB Type C with USB Power Delivery (USB PD) is just rolling out. USB PB is capable of delivering 5V/9V/12V/15V or 20V @ 3A to compatible devices There are also inexpensive converter that will allow you to get anything in-between.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
