Gdetrailer
Jan 18, 2020Explorer III
nicpaige wrote:
Im looking for suggestions for my audio system inside my 26' enclosed trailer/toy hauler conversion.
I will be travelling to both boon-docking and full hookup campsites. I will require a dvd/br player, bluetooth and android capable smart receiver either compact size maybe even a car touchscreen deck and amp Powered or passive small bookshelf or mini satellite speakers.
Any suggestions on systems or components? I will be without internet or cell service maybe 20% of the time.
There is no "one" system that can do what you are asking.
Figure out your priorities of what you want the system to do.
For instance, BT capable as what? BT to remote speakers? BT INPUT as in audio from a phone into the home theater system?
I personally prefer hardwiring speakers, just works and none of the BT connect/disconnect issues. Wiring speakers is easy and you can often find creative ways to get the speaker wires to the speakers without a lot of trouble or loose unsightly wires if you look round inside of cabinets or even some strategic wood trim installed to cover the wires.
Car audio is OK up to a certain point, then you run into a lot of limitations, for instance car audio systems do not have multi channel surround sound capability, they do often have a subwoofer output which will need a separate amp, they do not have HD video output so your TV is only going to get SD 480i video from a BR disc.
If home theater is what you are after, then go with a 120V home stereo receiver with surround sound and amps built in and hardwire the speakers. You will need to buy a separate BR/DVD player since home theater in the box systems with built in DVD players are not the rage any more and often the built in DVD player would fail before the rest of the system.
HDMI cable from the BR/DVD player to the theater receiver then HDMI cable from the receiver to the TV and you are done. HDMI carries HD video and the audio in one small cable. Makes for a very neat, clean hookup.
Of course while boondocking you will need a 12 to 120V inverter, those are plentiful and not all that expensive now days. Besides you will find having 120V from your batteries while boondocking rather nice to have.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
