Jay_Pat
Jun 24, 2013Explorer
I'm new to using Dish and the 1000.4 antenna.
I can find 61.5 using the settings from my zipcode list.
To get all three sats, I move the antenna to my right when standing behind the antenna. I adjust with azimuth and elevation only.
Run the switch check.
Just takes a little time to find all three sats.
Once I get all three, the next time I set up and use the switch check, if I get the "less than last time", sat message, (I know, lots of commas) I know to re-adjust and then run "check switch".
I hope this makes sense...
Pat
I have the 1000.2, LNB. Have not tried to point it. May be the same procedure.
Pat
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
