Community Alumni's avatar
Community Alumni
Oct 26, 2017
Need help with small solar project
Hi folks, this isn't RV related but I'm hoping the solar experts in this forum can lend a helping hand with my project.
I want to install a wireless IP webcam in a location where there are no electric outlets nearby.
The webcams consume 4 to 7 watts and are powered by 5 to 12V DC current. I want to install a solar panel and a battery that will power the camera 24/7 but don't know the size of solar panel and battery required to make it work. I also don't know if I'll need peripheral components such as a charge controller.
I have an old 125W automobile-type inverter with a cigarette-lighter plug lying around that I thought I could use and just connect the power adapter that comes with the webcam to the inverter.
For aesthetics reasons, I'm hoping a motorcycle or UPS backup battery will work so I can house all the necessary components in a small weather-resistant enclosure near the webcam.
If it helps determining the size of the solar panel and battery, the webcam will be installed in a full-sun location in the desert.
Thanks in advance for your help.
  • Sounds like a fun project.
    First off, get a multimeter and measure the actual current draw of the web cam. Cut the DC side of the power cord and patch the meter in series with one of the conductors, so power flows from the wall adapter, through the meter, through the camera and back to the adapter. If you don't want to do this, and your range is 4 to 7 watts, lets just round that up to 10 to make the math easy.
    The battery needs to run the camera, well, most of the time. 10 watts times 18 hours (conservatively) is 180 watt-hours. 180 watt-hours divided by 12 volts is 15 amp-hours... that's about the size of a garden tractor battery (I don't know what size a motorcycle takes, is it similar?)
    You want a panel that can push out 180 watts in 6 hours for the battery, plus another 60 watts for the camera... 240 watt-hours divided by 6 hours is 40 watts. You want a 40 watt panel, at a minimum.
    Yes, you want a charge controller. It doesn't need to be MPPT, that won't help much at these lower power levels... any 'ol cheapy off eBay will be fine. The controller is more to keep the battery from being destroyed if too much power comes in.
    Lastly, you don't want or need to use an inverter. Instead get an adjustable DC-DC converter, like a DROK and set it to whatever voltage your camera wants. This will save on waste caused by the inverter and waste caused by the wall adapter.
  • I tried something similar when trying to power some trail cams with other than alkaline batteries. I bought some small motorcycle like batteries off ebay that said AGM and they died quickly. The charger that came with them although rated correctly seemed to blow out one cam so I threw all that stuff in the trash and went back to duracell alkaline after also trying the Amazon alkaline AA batteries. Amazon AA are not comparable to Duracell. They are cheaper so given their performance they may be cost effective for some.
    I will also look forward to others ideas. Thanks for posting.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
