BoonHauler's avatar
BoonHauler
BoonHauler Solar Project
I told a few of you that I would post my Solar build here as well so here we go.
I had originally planed for an 800 watt array but since then I decided to double the size and I'm now at 1650 watts.
As some of you are aware I purchased six (6) SolarWorld ‘Sunmodule Protect’ series 275 Watt panels for my project. After much research I personally believe the SolarWorld ‘Protect’ panels are the most rugged and robust solar panels on the market today.
Here’s a pic of them coming in off the truck.
The panels are a 24 volt 60 cell configuration that’s roughly 66” x 38” in size, here’s a look at the panel.
The panels come pre-drilled for a two rail mounting system but being this was not going to be a standard static mount I decided to set them up as a three rail mount system. Here I’m drilling the panel side rails third (center) mounting hole.
I wanted the panel mount system to be fully tiltable in one axis. Here in this pic you can see the mounting system on one panel completed and ready for roof top installation.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
