Harley_Dude's avatar
Harley_Dude
Need Professional Stereo Voltage advice.
I replaced the cheap Jensen Stereo in my Jayco Eagle with a Pioneer Car Audio head unit with touch screen. Have replaced stereos in other RVs, so know a bit about wiring these units up. Wasn't hard this time and Stereo unit fired up and seemed to work well in all modes. A week or so later, I'd turn the screen display off and awhile later the screen lit up on it's own. Continues to happen. Then I got a screen with vertical lines running through it....hasn't been repeated to date. I talked to an audio installer in town and he stated that the head unit needed 14.4 volts and no more. Sure enough, that's what the spec sheet states....14.4 volts. He also stated that some RV converters can produce more than 14.4 volts and if that is the case here....there is my problem. He mentioned I may need a resistor for the head unit....but could give me no further help, other than to check the voltage with a meter.
Anyone here give me some guidance? Thanks
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
