texasredeye's avatar
texasredeye
Need Video Controller?
I have a 2007 Gulf Stream Class A. The previous owner had a DISH
antenna and controller installed. Consequently, the factory video controller was removed and is no longer in the coach. I have removed all interior satellite components and need to install a video controller which will allow reception from roof top antenna and shore cable. The TV cables are RCA pin type from both the front and the rear TVs. All the controllers I see are coax connectors. What controllers are the RCA pin type connectors. Are there any adapters available which will allow me to hook the pin type connectors to the coax on controller boxes today? What do I do? Anyone know what controller was originally installed in the coach? Is the original controller available anywhere?
  • SrFoxmexico wrote:
    Here is a link to what you are looking for
    http://www.amazon.com/StarTech-RCACOAXMF-Type-Coaxial-Adapter/dp/B003K1V99C/ref=sr_1_2?ie=UTF8&qid=1419608850&sr=8-2&keywords=coax+to+rca
    No go. These are simply a repeat of what I have. A RCA pin into one end then the connector is a RCA pin that plugs into a female RCA plug. I am trying to go from a RCA plugs to RF connectors not RCA to RCA.
  • donn0128 wrote:
    Why not just connect everything direct. Why spend money for something you might not need.
    Direct? There is nothing to connect to! That is the problem.
  • Why not just connect everything direct. Why spend money for something you might not need.
  • Here is a link to what you are looking for
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
