- Bill_SatelliteExplorer II
Kountryguy wrote:
It is my understanding that with Directv, for HD you need to align up two satelites instead of just one for SD programing.
This is correct. In reality, it's 3 satellites and not 2. The SD programming all comes from the 101 and the HD from 99 and 103 so you need one of the slimline 3 (or 5) LNB's and the larger Slimline antenna. No dome style antenna can receive the DirecTV HD programming.
Now, back to your original question. Every TV made will work!
I like the Vizio products and have a 32" LED in my coach now. - camperpaulExplorer
Not true.
All of the data required to display a High Def picture with stereo sound is contained in the HD signal from one transponder on one satellite. - KountryguyExplorerIt is my understanding that with Directv, for HD you need to align up two satelites instead of just one for SD programing.
- sch911ExplorerDon't be to disappointed by the SD picture on a Digital TV. The digital TV will just make the imperfections look worse. Why not upgrade the receiver?
- Old-BiscuitExplorer III32" LED/LCD Slimline Vizio.......Walmart
- SCVJeffExplorer
Kountryguy wrote:
Just pick one you like. None of them make stellar pictures from an analog input if that's all you will use it for.
I would like a recommendation for a new 32" led tv to use with a standard def Directv receiver. I would like to keep this receiver because it is so easy to set up. Any suggestions will be helpful.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
