Jul 22, 2014Moderator
TheBearAK wrote:
I must be awfully damn lucky then. I've recovered data on over a dozen hard drives in the past 10 years by swapping electronics. All of them have been the 3.5" drives, I've never had to do a 2.5" drive. I keep old hard drives just for this reason.
The Chip that was different on that video... it was simply a memory chip. Samsung switched from using ESMT memory to Samsung memory. Everything else on the board is the same.
Must have missed your earlier comment. Have you tried doing so recently? Assuming the failed drive in the video was just under a year old as he mentions when it was posted to YT? That makes the drive about four years old today. You don't think storage technology can change in that time?
TheBearAK wrote:
Could you imagine the manufacturing process that would go into testing every single drive and flashing a new calibration on each one of them? I call BS on that based on my own experience.
And, as long as the firmware is the same or newer, it works.
This does a better job of explaining what I'm referring to? Hopefully, you're good at soldering?
- If you were to buy two new identical hard drives and decided to exchange the printed circuit boards over to each other, the chances of the drives still functioning correctly is probably in the high 90's.
- But if you were to attempt this same procedure six months after normal operation, the chance of the drives working would drop to 5% and lower!
- The reason being that during a hard drive operation it will relocate sectors with degrading read times, this extends the life of a hard drive with automatic relocation of slow sectors. Unfortunately, this information alters firmware making the PCB unique to that drive, so it is imperative during PCB failure to physically remove this chip containing this unique firmware to a functioning matching PCB. In short, you can match the printed circuit board by model, family and country but firmware will need to be transferred and/or read and written to the new donor parts.
Source: www.harddrive-repair.com
So you're not likely to be able to just exchange the PCB board with the same(model) firmware or newer? If this info was erroneous, from a company that repairs hard drives for data recovery, then their business model must also be based on BS? Not likely as this is what I've also been told from other sources.
burlmart wrote:
This latest total loss of control of our W8 computer and the data stored thereon has been an eye-opener . I cannot tell you how much misinformation I have encountered in the past 4 days while trying to shake this problem down,
Actually, I think W8 does a good job in prompting users to complete recommended tasks, including making regular system image backups. My new DELL convertible also reminding me to make factory restore discs. Though I also have to believe that most users either ignore these suggestions or otherwise procrastinate, which can come back to haunt you.
If fact, my last HD failure years ago didn't catch me by surprise, as I had a monitoring app installed that warned me of problems 3-days prior to it completely failing. A new desktop HD just 10-days old.
But was prepared and had a complete cloned system drive already installed. So literally, just needed to re-boot my desktop PC, change the BIOS to recognize the new system boot drive, and was back up in about 5 minutes.
Notwithstanding, wish I had found that hard drive repair link above before writing this response, as it pretty much lays out the do's and don'ts for best practices for data recovery from HD failures.
And finally, be cautious of suggestions posted on sites like YouTube. I've come across totally erroneous instructional videos, which actually received high ratings and appeared legit, but were basically bogus info that I'm convinced was posted as a prank to see who would fall for them. That doesn't mean that some of these suggestions wouldn't work in the right circumstances. On the other hand, you also need to consider the consequences for doing so? Not to mention, the credibility of who actually is posting the info?
In any case, I don't think I can add anything else on the subject that hasn't been beaten to death. So, would agree with 1775 suggestions, including that it's time to move on? Good Luck!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
