senior290's avatar
senior290
No power to front TV
I have a 2003 Holiday Rambler and I have no power to the front TV. Can someone suggest a fix. All breakers and fuses are ok in the back bedroom.
  • senior290 wrote:
    I do not see any fuses that say they are specifically for the TV. Is there another fuse box in another location?
    The TV runs on AC current so it would have to be an open/bad breaker in the AC panel. The fuse panel is 12V DC. If this is the TV located over the driver's area it has a lockout relay for the 120V AC outlet that will not allow operation while underway. That relay could be bad or it's 12V DC trigger circuit bad too.
  • I do not see any fuses that say they are specifically for the TV. Is there another fuse box in another location?
  • Yes, Sorry I didn't say that. I checked the outlet and it has no power. Thank you for the quick response.
  • Don't intend to offend you with a stupid suggestion, but have you unplugged the set and plugged in something else, like a cell phone charger, just to make sure there is or isn't power to the receptacle? You mention the breakers/fuses at another location. Have you found the one that supplies the TV?
    I never make mistakes. Except the small front door deck I just painted with interior paint. Don't even ask why I'm using paint on a deck. Blame it on the VA loan inspector.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
