donn0128
Jun 15, 2013Explorer II
What ground antenna do you have? What receiver are you trying to run?
Typically a DVR has two inputs, so you need a dish/LNB with at least two outputs for each receiver if you want all of the functions to work. A single LNB output will work, but you will not be able to watch TV and record at the same time. Depending on receiver type and if you have a B band converter or not you might need to add that between the receiver and dish. Too many options and not enouh answers to go any further.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
