Two common causes of that
1: MSW inverters.. The slow moving gray line is a staple of MSW inverters in fact, that is called a HUM line.
2 Ground loops. though USUALLY they do not bother receive only installs. here is the problem
You have multiple TV's. all hooked to one distribution box, the box is grounded to the chassis (12 volt ground) and all the TV's are grounded through the 3rd wire to the same chassis.. This can cause issues.
You can easily test that one. You may also have A/V cables providing still more paths to ground (loops)
One way to test the 3rd wire loop is this.
Ebay LinkTry one or two of those on some of the sub systems and see if it helps. I keep one handy for other jobs anyway.
Ground loops are a major PITA.. There are ground loop breakers you can buy.
