Wife_nHubby's avatar
Wife_nHubby
Ntfs formatted 32g flash drve?
I'm trying to backup my HD. Windows 10 says I need a ntfs formatted flash drive. Hmmm.... how do I know ifor a flash drive is ntfs formatted vs Fat32?
  • As Mr. Wizard said, you just format/reformat it yourself. Most or all would come FAT formatted from the factory. Macintosh computers running recent versions of OSX do not (by default) allow writing to NTFS volumes, so a flash drive formatted that way would cause a good deal of tech support annoyance for the maker.
    I would suggest being somewhat careful about buying a large flash drive, particularly online. It would be wise to make sure that it actually has the capacity it claims to have. There are fraudulent knockoff drives out there that report to your computer that they are larger than they actually are, and if you try to use the space beyond what they actually have will lose data.
  • Dutch
    Those are ssd , installed in pc
    Not external USB for backup
    And way pricey, can buy a new pc for less $$
  • MrWizard wrote:
    you do understand, you GIGAbytes of external HD to create a backup
    a flash drive will hold nothing more than a few boot files and commands for reinstalling the OS, not your entire hard drive
    Hmmmm, me thinks you haven't looked at the available flash drives lately. Kingston makes them up to 1 terabyte now. A little pricey though, at $700+... :)
    Kingston HyperX Predator 1TB USB 3.0 Flash Drive
  • Click This PC icon or open Windows Explorer and right click the flash drive. Select Properties. It will list the File System under the Type of disk. If it lists FAT32 as the type, then you need to reformat the drive. Go back to This PC, right click the drive again, this time choose Format. Second option is File System, choose NTFS and then hit the button that says, Start. It should only take 15 - 30 seconds to format.
    -Michael
    -Michael
  • no problem
    this PC
    removable x? ( X being the drive letter assigned to the flash drive )
    properites (it might already be NTFS) if not then
    format
    ntfs
    do this before you backup
