wa8yxm
Mar 05, 2014Explorer III
Antennas 101
Take a map, lay it on a properly prepared table and stick a pin in it, THIS pin is your omni direcitonal antenna.
NOW. take a necklace chain,,, Arrainge it in a prefect circle aroudn the pin.. IF the station is within the chain, the Omni can see it,, Of course if there is a reflective surface behind the antenna but still within the curcle, that may cancel out the main signal.....
Now, Take a common craft (Popscicle) Stick and stick the pin back in the map, but now through the center of the stick.... Arrainge the stick so it points up and down from your point of view.. now pull the sides of the chain circle so it forms an oval about 2 times as long as it is high... That's the BATWING.
now take 1/2 of a 2nd craft stick and lay it against the first stick right were the pin sticks so the stick goes off to the right,,, Pull the chain to the right while shaping it abit so it is now EGG SHAPED. As you can now see that reflection from the back side of the antenna... No longer visible so it can not cancel the incoming. You might also notice your main lobe is much longer.
That's Batwing with Wingman
Now to add the Sensar Pro... you will need a much longer necklace chain.
Please note that the above is descriptive but is NOT to scale.. The actual difference will likely be greater than what I have described above.
The one time the Omni works well is if you are in the center of a fairly small circle with stations to the north, south, east and west all within about 30 miles... I tend to park 60-80 miles from transmitters I'm viewing during the summer.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
