Bobbo
Nov 22, 2015Explorer III
kregli wrote:
I think that was the model I had some years ago. If so, there is a control cable that goes to a control box and then two cables that carry the satellite signal. You can either bring these two cables in (one to each receiver), or bring (either) one in and use a DirecTV splitter to bring the signal to the two receivers.
A splitter will allow different channels to different receivers only if it is a SWM system and a SWM splitter. If it is not SWM, you MUST have 2 separate coax cables, one to each receiver, to get different channels on the separate TVs.
The SK3003 is not a SWM antenna.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Apr 25, 2026
