rockhillmanor
Nov 01, 2015Explorer III
rvingxtc wrote:
Thanks for all the suggestions. As far as changing the TV's around, I'mnow home and get no channels here at the house(not the TV's fault)
. I leave for hunting in a week, I will try switching them then. As far as now, I will check the connections--thanks.
I'm at my winter home in Florida. I had the house TV hooked up to the MH antenna for a while then for a whole 60 bucks I found this at walmart!
I now get over 20 channels inside the house for FREE.
No pole for an antenna needed. Just stick to wall inside and watch TV! I've tried quite a few of them and this one actually works. IMHO because it's a Winegard.
http://www.walmart.com/ip/FlatWave-Amplified-Razor-Thin-HDTV-Indoor-Antenna/27280272
8x10 piece of paper-thin plastic for an antenna, go figure!
The key to all these portable antenna's is to buy one with an amplifier. Most do not have one. The ones without an amp just don't work.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
