Bill_Satellite
Jul 22, 2014Explorer II
There is NOTHING he can do to prove your receivers are working. He can not do or see anything that would confirm your receivers are or are not working. The only way to know if a receiver is working properly is to connect it to a working antenna setup and see if you get programming. He can have you check the "check switch" settings but he would have no idea if that was correct or not for a Pathway X2. The correct check switch would be showing 72.7. If you are currently seeing anything else in your check switch screens the Dish folks would consider that correct despite not being so.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
