Ramblin__Ralph
Apr 10, 2014Explorer
Permanently installing 3G antenna on camper roof?
For the last few years I've successfully used a Verizon 3G USB modem when traveling. If not in town, I use a Wilson 301103 Tri Band (800/1900 MHz) magnet mount antenna for a stronger signal. Since my truck camper has an aluminum roof, I have a steel plate I use as the required ground plane.
I'm thinking about having a more permanent setup, by mounting the antenna on the roof. I'd epoxy the steel plate to the aluminum roof and use the mag mount. I'm thinking about using the roof TV antenna connecter to connect the antenna to the inside, vs. a new hole. I'd have to rig up some sort of adapter for the TV connectors on the outside and inside, since the antenna has an FME connector. Or, replace the FME on the antenna cable with a TV connector.
Any comments or other ideas?
Thanks,
Thanks,
