ulvik's avatar
ulvik
Plugging 30amp plug into inverter to power unit?
Hopefully I can explain this correctly. I am running 300 watts of solar with a 2000 watt inverter and was wondering if when boondocking I can plug my main power cord into the inverter to power all of the plugs inside the unit.
I was explained that you had to turn off the breaker to the converter built into the unit to keep from damaging it. But was also told if the Converter breaker in the units breaker box is turned off the outlets wont work.
So question is can I leave all the breakers on inside the fuse panel while I plug the main power cord into the inverter? Don't want to damage anything. I also understand I am limited to what I can use but want to use it for just lights, TV, ETC.
Any and all advice would be greatly appreciated!
    Yes.
    No - only the outlets connected to the same breaker as the converter are the ones that won't work.
    No. You don't want to be running your electric water heater.
    Lights are 12v.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Sep 26, 2025
